86 Iroc Guages - Metric or U.S. Help ?
Old Mar 4, 2003 | 10:01 AM
redlines4us's Avatar
I bought an original 1 owner '86 Iroc Z. I just noticed that the guages are kind of odd. The oil pressure guage numbers are 0-200-400 and the temp guage numbers read 40-105-125. These seem to be metric guages. I spoke to the original owner and he assured me that nothing has ever been changed since new. Could this be possible? I've attached a picture if anyone thinks they could help me. Thanks! Bill
The speedometer goes to 85 mph and 140 km/h
The tach goes to 70 and redlines between 45 and 70
The fuel guage has a picture of a gas pump and has only round symbols for empty, half full and full. (No words)
The amp guage reads 8-13-18. This seems to be U.S.
P.S. I can email pics of my speedometer, odometer, fuel and amp guage. I can also provide the vin number. Check out this picture and see what you think.
Old Mar 4, 2003 | 10:20 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 86 Iroc Guages - Metric or U.S. Help ?
It's a metric cluster. The Speedometer goes to 140 km/h, the oil pressure gauge is in kPa, temperature is in degrees Celsius, you don't have an "amp gauge" it's volts, and a volt is the same anywhere, even in the benighted U.S.
Old Mar 4, 2003 | 12:01 PM
Is a metric cluster common for an '86 Iroc sold new in Pennsylvania?
Old Mar 4, 2003 | 02:38 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Probably not. How sure are you that it's a one-owner car? Do you have the RPO list?
Old Mar 4, 2003 | 10:39 PM
I'm sure it's a one owner car and I have the original bill of sale, a copy of the original title, the window sticker and the complete RPO List still on the glovebox lid.
Old Mar 5, 2003 | 12:05 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Do you have NM5 or Z49?
Old Mar 5, 2003 | 01:16 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Yeah its a Metric cluster. I'll do you a favor, send you my cluster from my 86 IROC thats is standard, and you send me your Metric cluster. I wont get confused.
Actually, I'm going to look for one on EBAY, right now.
Welcome Aboard!
Old Mar 5, 2003 | 11:53 AM
Thanks guys,
This has been fun decoding all these numbers except a few. I double and triple checked, and the RPO codes I have listed here are correct and the ones I can't decode are also correct.
This car is really odd. It seems like the odometer doesn't correctly fit the width of the opening for the numbers. I'm absolutely positive that's it's the original cluster. Anybody see anything rare or odd in any of these codes as to why the metric stuff? Check out the attached picture of my odometer.
Thanks! Bill
AM9 Seat Back, split folding rear
AR9 Seat, FRt, Bkt, European Style, Pass A Driver Recl
A01 Tinted Glass, all windows
A31 Power Windows
A90 Power Hatch Release
BS1 Insulation, Acoustical Package
B18 Ornamentation, Intr, Deluxe
B2G
B34 Floor Mats, carpet insert, two front
B35 Floor Mats, carpet insert, two rear
B4Z IROC PACKAGE
B9K Ornamentation B/S Mldg, Reapply To RR Doors Only
B94 Ornamentation, Extr Emblem, Body, Var 1
B97 Ornamentation, Extr Mldg, Lower Accent
CD4 Windshield Wipers, intermittent (std Berlinetta)
C49 Defogger, rear window
C60 Air Conditioning
DK6 Console, roof
D08 Paint, High Gloss Finish
D34 Mirror, Visor Vanity
D35 Mirror, Outside Rear View
D42 Cover, rear compartment cargo area
D6F
D80 Spoiler (included with Z28)
D88 Decal, Stripe, Sport
E5Z Speedometer, Adapter (Delete)
E7Z
E9Z Speedometer Key (Delete)
FE2 Suspension System, Ride Handling
GC5
GC6
GU5 Axle Rear, 3.23 Ratio
G80 Rear Axle, limited slip
J65 Brakes, power front disc and rear disc
K05 Heater, engine block
K34 Speed Control, with resume
K90 Generator, 108 Amp
LB9 Engine, 305ci, 190hp V8 (Z28 only)
MD8 Transmission, Auto 4 Spd, THM 700 R4
MX0 Transmission, automatic with overdrive
NA5 Emission System, Federal, Tier O
N96 Wheel, 16 x 8, Cast Aluminum
NK3 Steering Wheel, Sport, Soft Rim, Simulated Leather
NOD Assembly Plant, Norwood Ohio
N33 Tilt Steering Column
N65 Wheel & Tire, Spare, Space Saver, Steel
N96 Wheel, 16 x 8, Wheel, Styled
P20 Hubcaps, Wheel Styled
QDZ Tire All, P245.50VR16/N BL R ST TL HW4
TR9 Lighting, auxiliary
TT4 Headlamps, halogen (4)
T63 Alarm, Headlamps On Warning System
T93 Lamp, Tail & Stop, Special
T96 Fog Lamps, halogen (included with IROC Z)
UA1 Battery, heavy duty
UP8 Stereo Radio Installment Provisions
UX1 Radio, AM/FM Stereo Cassette Equalizer
U21 Gage Package
U25 Lamp, Intr, RR Compt, Courtesy
U26 Lamp, Intr, Eng Compt, Courtesy
U29 Lamp, Intr I/P, Courtesy
U79 Speaker System, 4, Dual Frt Coax, Dual Ext Rge Pkg
VK3 License Plate, Frt Mounting Pkg
V73 Antenna Fixed
YE2 Radio, stereo, cassette, clock, s/s, equalizer
YR1 Seat, Frt, Custom
YS1 Seat, RR Cust
YT9 Option Package, Fisher Furnished Parts
Z28 Merchandised Pkg, Special Performance
Z31
Z49 Export Canadian Modif Manditory Base Equip
8NL Computer Selected Rear Lefthand Spring
82C Trim Combination, Cloth, Med Dk Gray (C) (91)
821 INterior Trim (Dark Medium Gray)
829 Seat Belt Color, Med DK Gray (91)
86A Stripe Color, Accent, Two Tone Red/Gunmetal (91)
86P Wheel Color, Gray Metallic
9NL Spring, Computer Selected, Rear, Right Hand
1A2 SEO, Vehicle, Public Service
41U Primary Color, Exterior, Black
6ZW Spring, Computer Selected, Front, Left Hand
7ZW Spring, Computer Selected, Front, Right Hand
Old Mar 5, 2003 | 12:27 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's not a metric speedometer face in the picture. If it really is original then you might have some kind of dealer-ordered screw-up. The metric gauges from from the Z49 Canadian export package, but you should have NM5 Canadian emissions controls with that instead of NA5 federal emissions.
Old Mar 5, 2003 | 04:20 PM
Here are a couple of codes I was missing.
B2G Components Of Iroc-Z Package
D6F Gear, Speedometer Driven
E7Z - Sensor, Vehicle Speed - Delete
Z31 - Advanced Price Sheet, Canadian Models
I think this car was possibly made for Canada and was imported to the USA and sold new here. It also has the engine heater.
That still doesn't explain why the numbers don't fit in the opening on the odometer. I just got off the phone with the original owner and nothing has been changed on this ar since new except tires, plugs and plug wires. It's still got the original brake pads, exhaust and 23,299 original miles.
Old Mar 5, 2003 | 09:42 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
the original us spedo only has room for 6 digits, you have 7 there. the dealer probably put on a us face and left the metric odomoter in there.
thanks
anthony
Old Mar 6, 2003 | 11:04 AM
Thanks anthony,
That would explain why the numbers don't fit correctly. I knew someone would have the answer. Bill
Ghettobird52
Jul 5, 2024 11:18 PM
AUZ28
Aug 26, 2015 06:08 PM
AUZ28
Interior Parts Wanted
Aug 25, 2015 07:29 AM
355sbcTPI
Aug 19, 2015 04:38 PM
mustangman65_79
Aug 11, 2015 03:17 PM
