Wheres That *%&@# Buzzer?
Old Mar 6, 2003 | 05:04 PM
rockfourone's Avatar
ok when i finished swapping my pedal assys for my auto to stick swap, i got a new problem. when i turn on my lights, the buzzer comes on even when the key is in the run position. if i pull down on the steering wheel then it goes off but my gauges dance and my warning lights dim. i really dont feel like tearing apart my dash to find the wiring problem so does anybody know where that little buzzer is so i can take it out and smash it with a hammer and then burn the pieces?????
Old Mar 6, 2003 | 05:34 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
If you must, it's located in the 'convenience center' above the drivers right leg, next to the console, hidden by the hush panel. Your hazard warning flasher is also located on the same panel, and the turn signal flasher is nearby.
Pete
Old Mar 6, 2003 | 11:31 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Pete
Exactly what he said, but I think you did something to your ignition switch, or something down there. Maybe its some wires going to the convenience center, who knows.
TekViper
Nov 7, 2005 05:00 PM
91rsowner4life
Mar 12, 2005 07:42 PM
jess
Mar 26, 2004 10:26 AM
Wheels
Mar 2, 2003 09:52 PM
BAK12484
Jan 15, 2002 02:21 PM
