Aftermarket in dash Speedo's
Old Mar 11, 2003 | 02:56 PM
84BlackZ's Avatar
I recently did the t56 swap and I ran into some problems as far as the speedometer. At first I bought a 90' Camaro Cluster and then came to find out that I would have to swap in a entire dash. Well, I scratched that idea. Has anyone got any Autometer or aftermarket electronic in dash speedos installed in a cable driven cluster? I do have the SGI-5 Dakota calibration box, however, with the Autometers I think there adjustable. But I was just wondering if anyone has done that, and if so, direct me on which speedo to get.
Joe
84Z28
350 sbc bored .060 over
CompCams Xtreme Energy Cam .477/.480 lift w/ 268 Dur.
SpeedPro Hyp.Coated Alum. Pistons
Cast Heads with .202 valves- Ported and Polished
Performer RPM Intake
Holley 750cfm with vacuum secondaries
CompCams 1.6 Roller Rockers
Melling Z28 Hi-Output Oil Pump
97'T56 transmission
Ram Clutch
Centerforce Flywheel
10 bolt w/ Aubourn Posi & 3.42 Gears
Rear Disc
GTA Wheels
Harwood 4" Cowl Hood
Old Mar 11, 2003 | 04:40 PM
hydrota85's Avatar
i am also considering doing this because my current speedo is not working since i converted from a 700R4 to a TH-350 I would like to see how this is done.
Old Mar 12, 2003 | 04:41 PM
84BlackZ's Avatar
Anyone at all? Some info would be awesome.
Old May 13, 2003 | 12:08 AM
DirtySouthSS's Avatar
Bump on this. I am running a different tranny and have no clue how fast im going I also need an aftermarket speedo.
Old May 13, 2003 | 02:34 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
yes it should work.
i talked with autometer, their electric speedos are calibrated after you intall. you basicly hit a button, then drive exactly 2 miles, and hit the button again. and BOOM it is callibrated.
Old Nov 14, 2005 | 01:41 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
opps
GTAman
Jul 3, 2024 07:29 PM
MantyZ28
Nov 8, 2015 06:54 PM
TrevinE
Sep 14, 2015 03:20 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
andy74
Sep 3, 2015 08:41 AM
