Anyone know how to fix the gain switch?
Car: 1988 GTA Trans Am
Engine: pos 305
Transmission: 700r-4
alright, i found instructions to wire your aftermarket amp to the gain switch in my gta, but the problem is the on/off button works but the slider switch doesn't, i can't figure out how to take the damn thing apart and its making me mad. i sprayed some of that dust remover crap in it and that didn't help, if anyone knows how to fix this i would appreciate the help.
Engine: pos 305
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
i wouldnt take it apart the housing can break easy then you are SOL'd.
see if you can find a buddy whos got a simple voltmeter and measure the resistance differences when you slide the thing back and forth. if you see a change the slider is probably working OK and you have another problem. another thing you can try is hooking up a light or LED instead of a speaker (and use 12v or such as power instead of head unit) and see if the light gets brighter or dimmer when you slide it.
Street Lethal
Apr 30, 2019 12:14 PM
86IROC112
Aug 17, 2015 02:00 PM
