electric cooling fans wont turn on....
well when the car first starts up the temp guage should peg to the high side and then go back, if it doesnt then most most likely the guage sender is dissconnected or broke..
as far as te fans go, did you test then to see if they even work, if they do i would look at testing the relays, and the fuse..
db057
Aug 11, 2015 10:11 PM
