Anyone ever figure out tach jumping problem?
Old Mar 18, 2003 | 09:52 PM
Carguy00's Avatar
I have searched the archives and haven't really come up w/ an answer. Tach that just pegs when started. Fuses are good. Let me know if you know how to fix.
Old Mar 19, 2003 | 09:38 PM
Mirthman's Avatar
Car: 1988 GTA Trans Am
Engine: pos 305
Transmission: 700r-4
yeah i got the same problem in my GTA, we need help people.
Old Mar 20, 2003 | 09:45 PM
chitowncruiser's Avatar
Car: 1996 Camaro
Engine: 3800 V-6
Transmission: 4L60E Automatic
Guy's.........I had the same problem with my 92 Bird.......the tach would jump around after getting over 2000 rpm,s......I changed the ICM = ignition contol module ....in the distributor and the problem went away..........that might be a good place for you to start........good luck.......
Old Mar 21, 2003 | 04:44 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
I had the same problem, replaced the module, and it seemed to help. I always thought that it might have something to do with the capacitor located on the firewall right behind the dist. I was thinking that the signal was too strong for the tach right off the coil, so a capacitor or something that would reduce the signal in strength but not in quantity would help to even out the tach. Just an idea...
1986Z28OWNER
Dec 13, 2015 10:19 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
stalkier
Aug 7, 2015 04:49 AM
