heater blower problems
Old Mar 20, 2003 | 11:02 PM
mypurple92rs's Avatar
Car: 86 iroc
Engine: 350 carbed
Transmission: t5
i'll try to discribe this this the best i can,but i'm sure i'll forget something.Last fall right before i put the carmaro up for the winter the blower died all three setting didn't work. well the warm weather is here well sort of i pulled the blower out it seemed to spin freely.Before i tried jumping it to a direct 12v source it put a meter up to the blower wire turned the keys to on and turned the fan speed on high went out and checked and it was getting 12.xx volts ok must be the motor turned the keys to off went out to disconnect the meter and it was still getting 12 volts.any help would be great:
Old Mar 21, 2003 | 05:56 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
If the blower won't run with 12 volts applied to the motor the motor is bad. The blower motor gets voltage 2 ways. The first slower speeds get 12 volts through the switch at the control console through a multi-tap resistor located in the engine compartment. It sits in the blower stream, you can identify it by looking for a 3 wire plug. The high speed is controlled by the relay located in that area. Try pulling the relay connector off and see if the 12 volts goes away with the key off. Perhaps the relay contacts welded shut.
Old Mar 21, 2003 | 12:02 PM
Car: 86 iroc
Engine: 350 carbed
Transmission: t5
well the fan works i'm going to but a new realay over the weekend but i'm have trouble with the 3 pin harness the think i found the resistor but i can't find the harness (alot of wire were hacked up when i bought this car )thanks
Old Mar 21, 2003 | 12:18 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
yeah i have problems with mine too
I only have the 2 speeds......even tho all 3or4 positions still work????????Both speeds seem kind of slow but maybe these cars are all like that. Does anyone think its a relay??
Thanks guys
Old Mar 23, 2003 | 07:36 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
It's the flat plug in the front, sorry it does have 4 wires. That plug goes to a resistor package to vary the speed of the blower motor.
Old Mar 26, 2003 | 09:53 AM
Car: '81 Trans Am
Engine: 6.6L
do you think that could be my prob??? the resistors or is like a hispeed fan not turning on on mine?????
Old Mar 27, 2003 | 05:10 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
The only way to test it properly is to meter the 12 volts to the motor as you step through the different speeds. As you increase the speed you should see a gradual increase in DC voltage to the motor.
Old Mar 27, 2003 | 09:29 AM
Car: '81 Trans Am
Engine: 6.6L
Ok cool i can do that....but if I find out its not sending the gradual increase where is this resistor pack located???
Old Mar 28, 2003 | 05:41 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
In the engine compartment on pass side to the right of the blower motor you will see a 4 wire plug, the resistor is in the duct and has air blowing across it to keep it cool. It is held in with a couple of self tapping screws.
Old Mar 29, 2003 | 09:14 PM
metalgod's Avatar
hey dude i might be able to help, since i had the same trouble. instead of checking the + 12 volts turn the key with the blower on and ground the ground pin to the body, thats how i got mine to work. i left the ground wires on the drivers side of the engine off and thats when i noticed my heat didnt work, but try the ground method
Old Mar 30, 2003 | 02:32 AM
RdDgg71's Avatar
i had the same problem when the blower was off it wouldn't turn on and when it finally came on it wouldn't shut off all you have to do is change the relay it is really big right in the center of that other guys pic
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
soarestransam
Sep 1, 2015 04:00 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
mhatfield 14
Aug 15, 2015 10:47 AM
