Got new cluster, still got problems
Old Mar 27, 2003 | 03:56 PM
peacefrogs72's Avatar
K, when I started my car (just bought it 84 z28 HO), the tach pegged high when started, so I bought a new cluster off ebay (guy claims it worked great when removed from an 85 z28), problem is, now tach works, but is WAY off, Idles at 2500rpm, pegs at probably around 2500 true RPM. Is this what would happen if it's a v6 tach(what I suspect)? Tried intermixing parts with the old tach, but the problem is on the circuit board, so that won't help, swapped the little yellow box on the back of the cluster, didn't help.....
Anyone know what the voltage should read to ground on the tach wire (ie conversion volts to rpm)?
Any help would be appreciated.
Thanks all
Old Mar 27, 2003 | 03:58 PM
addition
Sorry forgot to ask, would it matter if the new tach came from a tpi car?? Not sure if it did, but would it matter?
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
