Car turns but wont start!
Old Apr 3, 2003 | 09:36 PM
cllimp101's Avatar
I have a 85 z and i just did some rewiring with the ingnition wire from the starter and also another red wire (?). The car was running fine after that, then i went to start it and all it does is crank and the gauges are all working but it wont start. Need help plz
Old Apr 3, 2003 | 11:04 PM
2vmodular's Avatar
an ignition switch color code guide is avaliable here:
http://www.p71interceptor.com/thirdgen/alarminfo
Old Apr 4, 2003 | 09:06 PM
cllimp101's Avatar
Thnx, but i think i might need a new computer for my car. when i turn the key nothing happens, also the check engine light doesnt come on and the fuel pump doesnt prime or make any noise at all. its like the car is dead but there is still power????? I am confused any other suggestions
Old Apr 6, 2003 | 11:06 PM
AFRO IROC Z's Avatar
I don't know where it is located on your car, but try finding the fuel pump/ ecm fuse. It will cause the problems you described. On my 87 iroc it was about 6 inches away from the battery zip tied to the fender. And it was in a black capsule, so you won't know there is a fuse in there unless you open it up. I think it is a 20 amp fuse btw. Hope this helps good luck
Old Apr 8, 2003 | 12:25 AM
mrt89rs's Avatar
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
it sounds to me like it is an ecm fuse that is causing that problem (good fuse to pull out when you don't want anybody to steel you car) the ecm fuse should be the a 10amp fuse on the top right coner of your fuse box. your fuel pump fuse shoud be next to your battary up aganst the weel well, hope this helps.
Steven 86IROC-Z
May 24, 2026 04:52 AM
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
