How much amperage flow can the stock headlight harness and switch take???
Old Apr 12, 2003 | 01:25 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
I have aftermarkte fog lights and was thinking of wiring them in with the low-beam headlights. How well would this work? I was thinking I could also do a manual switch just in case I didn't want the headlights on also...
Basically can the stock headlight harness take the extra flow of a couple small fog lights?
Brady
Old Apr 12, 2003 | 04:19 PM
Tyler-88's Avatar
not exactly sure how much it can take. i added aftermarket headlights so i can see where i am going. the total wattage of the 4 lights was 460watts. the factory wiring could not handle that
id run new wires right from your dash. or use the low beam wire to trigger a relay that turns on your fog lights
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Fronzizzle
Aug 19, 2015 01:36 PM
stalkier
Aug 13, 2015 12:59 PM
