Oil Pressure guage....
Old Apr 26, 2003 | 12:32 PM
Beast_Vert350's Avatar
My oil pressure guage isnt working and am thinking it could be the sending unit, is there anyway to test this? And where is the oil pressure guage sending unit located?
Old Apr 27, 2003 | 02:15 AM
Matty377's Avatar
Car: '86 Camaro
Engine: LG4
Should be sticking up out of the back of the block next to the distributor(toward the driver's side). It's a bell shaped thing with one connector going to it.
As for testing it...no idea how you would go about that.
Old Apr 27, 2003 | 02:19 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Ground out the wire that plugs into the sending unit, the gauge should peg out if working properly.
Old May 3, 2003 | 04:51 PM
are you sure thats the one? Some one also told me that it is also near the oil filter. I am getting confused now, I have a 1988 IROC convertible with a 305 TPI if that helps
Old May 3, 2003 | 10:41 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
'88 should have the sender at the top of the block as Matty described. Visually, you'll know if it's there or not if you peek under the hood.
Old May 6, 2003 | 12:49 PM
David Petersen's Avatar
Agreed ....my 88' was by the dist. cap. I had the same problem turns out the connection was just loose. I hope the same for you.
Old May 6, 2003 | 03:05 PM
88ROC1LE's Avatar
Old May 6, 2003 | 03:07 PM
Should add that my 88' was a 350 TPI maybe the engine type is the difference?
Old May 6, 2003 | 08:18 PM
Ok changed the pressure sender by the distributor, and am getting a high readiung like just under 60 at idle, its that good or bad? and why would it be high?
Old May 7, 2003 | 02:48 AM
Morley's Avatar
Thats about normal for a cold engine. Drive it a little and see if it comes down.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
