power window wiring + mirror
Old Apr 26, 2003 | 09:40 PM
Briansz28's Avatar
I got a "new" door from the junkyard and I want to get the window down to take off the interior panel off to get to the plugs. I tried but can't get the panel off with the window up. At the junkyard I cut the wires going to the door from under the dash. What wires can I connect to 12volt source to get the window down? Its the passenger side if that matters-from a 91 or 92 Firebird.
Also, is there a plug for the power window inside the door or does the wire run straight to a connector under the dash? I looked and could not see a plug for the mirror for my 84 Z-28 (where the door is going.
Thanks!
Old Apr 26, 2003 | 09:49 PM
jwattsjr's Avatar
Car: 84 & 86 T/A
Engine: LT-1 & 5.7L
Transmission: 700R4's
Should be Lt Blue and Tan. Judging by the diagram, you want to hook the Tan wire to
the positive side of the battery for down, and the negative side for up.
-Jeff
Old Apr 27, 2003 | 07:54 PM
Briansz28's Avatar
Thanks! I hooked up my tractor battery and it zipped down. Much easier to handle the door now!
Old Apr 27, 2003 | 08:03 PM
jwattsjr's Avatar
Car: 84 & 86 T/A
Engine: LT-1 & 5.7L
You're Welcome.
-Jeff
Old Apr 27, 2003 | 10:36 PM
Briansz28's Avatar
Power mirror hookup?
Does anyone have any info on where the plug is located for the power mirror? In the door? Under the dash? I can't seem to locate!
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
