redundant headlight motor, did search, help...
Old May 2, 2003 | 12:01 PM
Kaps's Avatar
Hey, I tried searching, didn't find too much. The left headlight motor on my 88 GTA has been over-running, like when it goes up and down, when its in position, it will still run for a lil while longer, very very rare I either have to tap the light take make it go up or down, but not too often. Anything I could do to prevent this? or am I on borrowed time until the motor completely fails? Thanks, and anyone know how to repair the motor, I thought someone wrote a tech article couldn't find it
Old May 5, 2003 | 07:42 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
Sounds like the gearing is bad and worn so it runs cause it didnt reach its limit yet, or the limit switch in the control module is bad. If the module is bad and its making the motor run extra then that will proabably wear the gearing out too.
Heres a link for repair.
http://www.shsu.edu/~stdvjs11/headli...ightmotor.html[/URL]
Matt
Old May 5, 2003 | 08:59 PM
MikeS's Avatar
Sounds like it is on its last legs before it needs the standard repair. Symptoms sound similar to mine before they quit altogether.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
stalkier
Aug 13, 2015 12:59 PM
