wiring harness
Old May 5, 2003 | 03:21 PM
ws689's Avatar
wiring harness
any easy ways to take out the wiring harness of a TPI without cutting it and making a mess, i'm using no sensors or other wires except the starter wires and the ele. fans, which i'm going to wire up seperately
Old May 5, 2003 | 09:10 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
Simply disconnect all the connections. Then pull the wire looms off the body.
I removed a '86 harness in about 30min(actually a bit more cause there are wires connected to the transmission so I had to get under there)
I only had to cut 5 wires cause I couldnt get to them. They were sandwiched between the block and firewall.
Matt
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
