i think i broke them!!!
Old May 3, 2003 | 07:59 PM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
Transmission: Borg warner T-5
i took the needles off he gauges in my cluster so i could put these white overlays on. but when i wentto put them on, i forgot where they were all pointing when i took them off. if i put all te needles back on pointing to zero, or lowet measurement will the gauge be in accurate now? the gauges are all electric.
please help
Old May 11, 2003 | 12:05 AM
The_Prostitute's Avatar
BUMP
I am in a similar situation and would appreciate an anwser...
Old May 11, 2003 | 12:55 AM
MasterEvilAce's Avatar
i'd say turn the car off, and all the gauges should reset, then put the needles all on 0.
but.. hmm. that's not the best way to do it, i suppose
Old May 11, 2003 | 12:57 AM
jgifford's Avatar
Car: 1986 Z28
Engine: 355TPI 380hp
Transmission: Rebuilt 700r w/ Transgo Shift Kit
dang, beat me to it.
IIRC, if you turn the key to on position, everything but the fuel gauge drops to zero. I'd pull the needles off again, turn the key on and go from there. As far as fuel goes, I'm not really sure the best way to do that. Good Luck
Jeremy
Old May 11, 2003 | 10:38 AM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
for the fuel gauge, I would ground the sender wire and the gauge goes to FULL (open, it goes to E)
Old May 11, 2003 | 11:44 AM
Is there any way to set just the speedometer to zero without installing it in the car? I would rather have everything assembled before I install it.
Pac J
May 17, 2020 10:44 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
wanext
Oct 6, 2015 12:18 AM
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
