Headlight / motor / fuse
Old May 6, 2003 | 02:03 AM
EmoDork138's Avatar
Car: 88 Trans Am GTA
Engine: 5.0 TPI
Hi, I was doing the wonderful "appoxy the gears in your headlights so they start to work" and found that flat out, one of my motors was just shot. So i jumped onto the ebay and bought a headlight motor that was said to fit my 3rd gen car. When it came in, this motor had 3 wires, and mine only had 2. Otherwise, the bolt patterns were the same. Me and the old man experiemented with some wiring patters and in that process blew the fuse to my headlights as is now my headlights and running lights do not turn on anymore. My question is this...
A.) Does anyone know how to wire the 3 wire headlight motors so that it may work properly with my other 2 wire motors?
B.) Where is this fuse that i blew?
I will right off the back apologize to all you firebird guru's out there for the stupidity and lack of knowledge, but im just a punk kid, and i have to learn somehow. Thanks for you help fellow 3rd gen fanatics!
1987 Firebird Formula, 350 bored, 4bbl
Old May 6, 2003 | 07:39 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
The fuse should be in the fuse panel.
As far as wiring, I dont think there is a way to wire it in. The 2 wire units simply reversed electrical flow to run the motors in both directions.
The 3 wire system actually moved the grounds. Similiar to this diagram.
------Blu---Grn---Gry
up: -------(+)------(-)
dn: (+)---(-)
You'll have to get a different motor. Just so you know, '84-'86 Fieros used the same motors. '82-'84 Firebirds and TA's used a different syle. They have a 2 connectors and 4 wires( 2 wires per connector).
You need a motor from a '87-'92 Firebird or TA or a motor from a '87-'88 Fiero.
Hope this helps some.
Matt
Old May 8, 2003 | 06:11 PM
EmoDork138's Avatar
Engine: 5.0 TPI
Thanks Matt...Through some trail and error, im finding out that you are correct But thanks for the reply! It is appreciated
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
LittleFranks
Sep 17, 2015 12:22 PM
stalkier
Aug 13, 2015 12:59 PM
