Ignition Coil
Old May 7, 2003 | 04:50 PM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
Ignition Coil
I want to replace the ignition coil in my car. My qustion is, what style,
in cap, on top of the cap, external, etc?
Will brand make a real difference?
Old May 7, 2003 | 11:38 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
It all depends on what kind of distributor you've got. All the styles work out very well. The ext coil, stock on my car, is the easiest to change, maintain, test, and so one because of its relatively accessable location.
Old May 8, 2003 | 01:08 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
you might as well install a performance coil. Screw the stock one. An Accel or similar coil isn't that much more than the stock part.
Old May 9, 2003 | 03:44 PM
Firebirdjoe's Avatar
Car: 1987 Pontiac Firebird 82k miles
Engine: 2.8 V-6 (173 c.i.)
One recomendation would be to not use an ignition coil from Auto Zone. I have heard many bad things about them. Your best place to go is Napa or Pep Boys.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
