fog light wiring
Old May 21, 2003 | 04:32 PM
PRLirocz85's Avatar
Car: 1985 Camaro IROC-Z
Transmission: 700r4 (rebuilt)
Axle/Gears: stock
fog light wiring
hi. ummm i'm sure that this question has come up before, & i've searched the tech articles & both old & new forums here, & elsewhere, but i just can't find it.
anyways i want my fog lights to work when my parking lights do. as of now the switch only turns them on when the headlights are on. would it be possible for someone to direct me to an article, website, thread, or whatever that explains how to do this?
Thanks.
Old May 23, 2003 | 12:15 AM
MdFormula350's Avatar
my foglights can be turned on when the parking lights are on
Old May 23, 2003 | 10:36 PM
PRLirocz85's Avatar
Axle/Gears: stock
ahh well... mine don't. Your diagram there should be helpful, though. Thanks.
-Patrick
Old May 24, 2003 | 08:58 PM
SinthetikIroc's Avatar
Car: Corvette
Engine: 5.7
mine come on when u flick the switch regardless of headlights. and thats with the stock wiring. 87 350tpi iroc
Old May 25, 2003 | 01:14 AM
EYEROCK89's Avatar
Car: 1989 IROC
Engine: 5.7 / 350 cuid
There isn;t really much to it...don;t let the diagram confuse you. Just splice the hot wire of each fog light to the hot wire of each parking light and you're done...just make sure you get the running hot on the parking light and not the signal hot wire. Pretty cut and dry. This is how I have the fog lamps set up on my IROC.
Old May 26, 2003 | 04:14 PM
PRLirocz85's Avatar
Axle/Gears: stock
Ahh plain & simple... You're the man! :hail: Thanks.
Old May 27, 2003 | 12:17 AM
EYEROCK89's Avatar
Car: 1989 IROC
Anytime, make sure you find a good place to ground the fog lamps as well. I had to run about 14" of wire to the chassis to make sure I got a good ground.
Old Jun 2, 2003 | 11:24 AM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
Just as a side note, I know here in PA it is a law that if you turn on your high beams that your fog lights must turn off...
Old Jun 3, 2003 | 06:02 AM
EYEROCK89's Avatar
Car: 1989 IROC
That is actaully a law? How strange. I always wondered why some fog lamps would turn off on newer cars when you hot the high beams on.
Old Jun 3, 2003 | 09:27 AM
Engine: 346ci LS1
Transmission: MN6
Yep, and it made installing the stock foglights into my Camaro a whole lot more complicated.... Otherwise I would've done it the easy way mentioned here! A lot of r i c e r s here with those aftermarket fog lights get busted for it. And pretty much any newer car that you can find with fog lights, they will turn off as soon as you turn on the high beams.
Old Jun 3, 2003 | 05:39 PM
EYEROCK89's Avatar
Car: 1989 IROC
Hmm, yeah, my Maxima did that so I hardwired the fog lights in. I hated when they would turn off. Oh well, thanks for the info.
jaridjohn
Jul 8, 2024 03:49 PM
TheExaminer
Aug 26, 2015 04:59 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
