Headlight Problem
Old May 21, 2003 | 05:40 PM
Syxx613's Avatar
Car: 1987 Trans Am GTA
Transmission: 700 R-4
Headlight Problem
Well i found that my passenger side relay was messed up and was causing my headlight not to pop up. So today i went to Napa and got a new one. I get home and put the new one in and push the lights to go up, and HOORAY THEY GO UP! However i push to go down.... and only one goes down. The one i just tried to fix will now go up but not down. What is the problem?
Old May 22, 2003 | 02:35 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
Possible causes:
-Bad isolation relay
-Bad connection or ground
-Faulty actuator motor limit switch
-Bad actuator motor
This is how they operate:
------Blu---Grn---Gry
up: -------(+12v)------(-)
dn: (+12v)---(-)
I think +12 volts should be present at the wires when thay are powered, though I'm not sure.
Hope this helps some, let me know if you need more help.
Matt
Old May 23, 2003 | 11:48 AM
Syxx613's Avatar
yeah that doesnt really solve my problem yet. Like i said the one headlight will go up perfectly fine, but not down. i dont know why. When i push the button to go down the light goes off on this one but the headlight wont go down. anyone else know whats going on here?
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
