Brights Switch Replacement - HOW???
Car: 92 Camaro RS
Found the switch at the bottom of the steering column. How in the world do you replace it. I can see one bolt and can feel the other back up above brake light switch and some other switch. Help please.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Sometimes to make it a little easier to access the switch (red arrow), you can take a little extra dash trim off and remove the 2 - 13mm nuts (in the area of the green arrows) holding the sterring column up. This allows you to lower the column slightly and gain some extra working room.
Ghettobird52
Jul 5, 2024 11:18 PM
