Power Locks
Old May 27, 2003 | 09:39 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Power Locks
I just purchased my car and the power locks don't work correctly. When pressing the button to lock they make a noise sounding like they are trying to lock but don't do anything. When the doors are locked and I press the unlock the lock slides to unlocked but not very forcefully. Thanks for any insight.
Old May 29, 2003 | 10:04 PM
KidTransAm's Avatar
check out your lock soleniods..pop off your door panels..and theres a rubber boot on top of the soleniods (or however you spell em) anyway..you can lift that boot..and spray some wd40..or better ..some white lithium grease on em...and grab the linkage with your hand and manually work them for a minute...see if itll loosen them up...if that doesnt work..check to see that they are getting enough juice to them..(bad connections can make them `half work`) if none of that works lube up your linkage everywhere including the lock mechanism..and if that dont work..plan on buying some soleniods. hope this helps
BRoss99
Aug 10, 2025 05:08 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
mantaguy
Sep 1, 2015 08:39 PM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
