How would I wire that GAIN button up to a new cd player?
Old May 28, 2003 | 10:27 AM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
Hi, I own a 86 Trans Am and was wondering what the wire looks like that comes from that GAIN button thats supposedly gives more bass. Well anyways, I want to know if its possible to wire that GAIN button up to a new cd player I'm going to be buying shortly? How would I do it? Thanks for all your help.
Old May 28, 2003 | 04:33 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
only if you are using the auxilary outputs on the head unit to go to an amplifier before the speakers.
Old May 29, 2003 | 07:31 PM
ajm_shorty's Avatar
i have an amp in my car but i still dont know what your talking about. Can i use that switch like an on/off switch for the amp and also feed the amp less power?
Old May 29, 2003 | 09:23 PM
Diggler86's Avatar
Car: 86 TA
the switch can turn on and off the amp.
also the slider can reduce the level of the signal in the rca lines. but however it will be mono.
here's a pic, theres also a thread about the wiring maybe i can find again.
Attached Thumbnails How would I wire that GAIN button up to a new cd player?-switch.gif
Old May 29, 2003 | 09:34 PM
ajm_shorty's Avatar
so there are RCA cable inputs on the back of that switch? I want to be able to make my Amp Out put Got up and Down from that switch
Is that possible
Old May 29, 2003 | 09:58 PM
Diggler86's Avatar
Car: 86 TA
there are no rca cables on the switch, you have to buy some rca cables, cut them and connect them to the switch.
Jorlain
Aug 24, 2022 05:11 PM
stalkier
Aug 21, 2015 01:54 AM
smooth
Aug 18, 2015 06:34 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
