Battery keeps dying
Old May 28, 2003 | 03:55 PM
Fbird88's Avatar
Car: 1988 Firebird
Engine: GM Performance Parts 350 HO
Axle/Gears: :(
Battery keeps dying
My battery keps losing power, I'll charge it up and it lasts for only 3 or 4 drives. These are really short drives, so maybe the alternator didn't get fully charged..? I have dual fans, a 4th gen mini starter, and the stock L03 alternator. This is at least the 5th time this has happened. Also ithe engine usually starts on the 2nd try. The power doesn't drop to 0, just keeps dropping until the engine won't start. What could possibly be causing this? Any help or ideas for me to check out would be greatly appreciated.
Old May 29, 2003 | 11:07 AM
Z28Clone's Avatar
battery isnt holding a charge. get a new one
Old May 29, 2003 | 11:19 AM
ZFORCE's Avatar
Car: '87 IROC
Transmission: TH700R4
Have the alernator checked out or pull the positive cable while the engine is running and see if it stalls. If it does it is most likely your alternator (make sure batt. is fully charged before attempting).
Also, if you have a multimeter, check the mA (amps) draw on the battery with the engine off, you may have a draw on the battery while it is sitting that is draining your batt.
tj
Old Jun 1, 2003 | 06:11 AM
aussierob's Avatar
Yeah thats right pull the positive cable of the alternator and you will really stuff up the alternator. Doing that is a no no. Just measure the voltage at the battery terminals (make sure they are clean and tight), should be around 14 volts. Quick check of the battery you can do is with engine off measure the battery voltage with lights on and other acc. you may have. The voltage should still stay around 11-12 volts, if it drops off quickly below 11 volts batt. is stuffed. Also leakage test is good incase of any problems with internal wiring. Another way to test batt is to charge it and remove from car and let sit on bench not connected for a day or 2. When reconnected to car if it cant start then you know for sure the batt isnt holding charge and your car wiring is OK.
Old Jun 1, 2003 | 07:13 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Replace the Alterntor with a new Delco 105 amp one. If the battery will not hold a charge and it keeps losing power its the Alternator. They do go bad, and if its the stock 85 amp one more chances thats the cause so check it out.
Old Jun 1, 2003 | 10:36 AM
Fbird88's Avatar
Car: 1988 Firebird
Axle/Gears: :(
Well, I took it to a shop and they tested it and found that the battery was bad, the alternator was good, the battery cables were too small, timing is advanced a little too far, and a ground cable to the block was loose. I got a better battery and grounded the cable and the problem is all but solved. Thanks again for the help.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92firebirdguy
Sep 1, 2016 07:53 AM
z28joe2
Sep 28, 2015 05:54 PM
Lmancha96
Sep 25, 2015 08:11 PM
lanceflame44
Sep 25, 2015 12:28 PM
