wiper motor wiring 82-83 owner
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
hey guys need help re-wiring my 82's wiper motor, but heres the problem, my dash harness and everything else is from a 87, however the 87 wiper motor won't bolt up to my car, so Im stuck using the 82 wiper motor, can any of you take a test light and probe your 82-83 wiper motor and tell me which terminals get power and so on I have intermitant wipers if theres a difference
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
two pink wires should be hot, white ones would be ground controls from switch
if you remind me tommorrow AM with an email message then i will check this on my 82 out here for sure,
my hood is off and the engine is out and batt power is connected to car because i was tracing and repairing wires from console and fuse panel areas today to make courtesy lights and turn signals work again, and to remove that junk aftermarket sterio and speakers mess of Fugly wiring
fast
already got the wiper motor working, I have a nice 83 cfi harness from a trans am if your unable to resolve your wiring issues, thanks for the help anyways
eightsixseven
Dec 16, 2024 01:50 PM
