maf trouble
Old Jun 6, 2003 | 10:18 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
maf trouble
need help here, first off what Im dealing with is a wiring harness from a 1987 gta 350 trans am that I put in my 1982 trans am, I get a consistant code 33and Im ready to say to heck with the maf system and run a painless speed density setup I have, here is the maf I'm using bosche 0 280 213 004 14 094 712, is this the correct one for a 1987 ? Ive read on power to the maf plug when I jump terminal G (I think) I get power to my red wire on the maf plug, and while the car is running it also has power, however I can never get power to the blue wire no matter what I do, can any one tell me exactely which relays are for power and burn-off by wire colors since mine arent in the same location so a picture won't help me much, Ive traced most of the wires and none seem damaged, I've tried two ecm's and two USED mafs without any improvement, is this a definate maf problem or simple wiring issue, I don't especially feel like spending two hundred bucks for nothing, or is anyone in southern california that can help me straighten this problem out
Old Jun 7, 2003 | 04:03 PM
Jproz1167's Avatar
don't respond, gave up on mass air flow and re-pinned my harness to run speed density ...... MAF a 3 letter word for trouble
Mark_ZZ3
May 24, 2018 01:02 PM
mrbird
Oct 20, 2015 03:43 AM
racereese
Oct 3, 2015 03:46 PM
Lmancha96
Sep 25, 2015 08:11 PM
