headlight motor is hot
Old Jun 8, 2003 | 06:54 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
ok on 82 firebird headlight motors, driver side one has aluminum manual **** and the motor gets hot pretty quick when lights are turned on, pass side motor has a black plastic ****, neither headlight pops up, both relays intact by motors, why do my headlight ***** not match and why is driver side motors getting hot ? headlights do work though, just wont come up
thanks for anything
Old Jun 22, 2003 | 02:39 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
ttt
Old Jun 22, 2003 | 03:22 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
Never heard of the motor getting hot before. Also never heard of an aluminum ****. Maybe it gets hot cause of excessive current draw and becuase the **** is metal.
As for not goin up: There are 3 relays. The 2 you already have and one on the passenger side radiator baffle. This relay is the Headlight Motor Isolation relay. It is a dealer only part. It is not interchangable with the other relays. It may be bad or missing. Replace it if neceessary. It runs about $25. The other 2 relays may also be bad. They are available at pepboys or autozone or places like that. They run about $15 each. Just bring one in and show them. I think GP Sorenson makes them. PN MR86 I think, not sure though.
Check the red/white power wires for +12 volts. Power must be there for them to work.
Let me know what you find.
Matt
Old Jun 22, 2003 | 05:16 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
cool thanks, good info, are the wires always hot to the relay(s) when lights are turned on ? if so then to which relays ?
thanks
Old Jun 23, 2003 | 10:27 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
cant believe hot motor has never happened to anyone on this forum, and no one here has seen aluminum gray colored **** on an 82 ???
crazy,........
thanks
Old Jun 24, 2003 | 04:13 PM
Matto'85TA's Avatar
The red wires are always hot. They run to the motor relays located on the inner fender wall on each side. The wires are either red or red with a white stripe. Power is supplied to them by fusible links.
Matt
Old Jun 24, 2003 | 05:57 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
cool thanks, i found out about the aluminum **** thing, yeah.
all the motors are aluminum ****, the black plastic ***** you all see on oyur motors are just athin plastic cover they coem right off, aluminum metal four hole **** underneath that !
someone removed one of mine and its just gone, thats all
odd how no one ever knew that, no one has ever removed one ?
im baffled.
thanks
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
DiabolicalRS
Aug 26, 2015 07:35 AM
stalkier
Aug 13, 2015 12:59 PM
