online underdash wiring diagrams ?
Old Jun 9, 2003 | 02:31 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
anyone know where to find underdash wiring that will show ALDL connector wiring and headligh motor and relay wiring and the brown wires and light blue wiring for the green relay next to horn relay? haynes manual has none of the above in it... grrr...
thanks for anything!
R
Old Jun 9, 2003 | 08:20 AM
1986redbird's Avatar
check on the main page of this site, there is a tech. section that has a bunch of scanned wiring diagrams there, you may find what you are looking for.
Old Jun 9, 2003 | 11:08 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
thank you! !
and thannks for anything further also
i still cant find what the pair of wires that are orange and orange wiuth black stripe at shifter area of the consoel assembly are for, one is cut, and i cant find connector for cig lighter,
this is a firebird
the wiring digram just shows orange wires and none with stripe,
i cant read what fuse panel slots are labeled, that stuf fis worn off, or id pull the cig lighter fuse and see if the cut orange wire goes dead.
should lihter always work or just with key on ??
and id like to find out about the smaller brown wire from ALDL connecotr underdash and over to front left hand corner of interior compartment under the dash with the large harness there, i highly doubt its inviolved wewith lights like most brown wires usually are
thanks
Old Jun 9, 2003 | 12:06 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Randy
my 82 had a orange/black stripe wire going to the nuetral start switch, that went to the ecm, the solid orange wire should be battery feed
Old Jun 9, 2003 | 12:53 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
yheah both of the orange wires under console are batt feed, wish i knew what they went to and why ends are cut off including an orange with black stripe ground source wire also thats paired up with one of the two soid orange wires in same connector end.,.
thanks!
Old Jun 13, 2003 | 02:35 AM
LI Tommy's Avatar
Hey Fast69,
The Lighter should have juice even without the key on. Furthermore, The solid orange one is probibly for the lighter.I'm not sure what else, except the Neutral Saftey and radio's battery back-up (which is solid orange), under there that needs constant voltage? Are both of those hooked up?
Got me on the brown Wire!
Old Jun 15, 2003 | 12:09 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
not hooked up, one orange wire and anotgher ine with blasck stripe are paired together in same connector and all by themselves, and anotgher orange wire is all by itself there too, did lighter get black wire to get ground, also ?
thanks
eightsixseven
Dec 16, 2024 01:50 PM
Street Lethal
Apr 30, 2019 12:14 PM
camaro11j
Sep 19, 2018 08:49 AM
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
