berlinetta gets no power... sometimes
Old Jun 17, 2003 | 05:45 PM
xChRiSx's Avatar
my 84 berlinetta has a problem where it will start sometimes and run normally, but sometimes the dash will flicker and go out and all the electrical things in the car won't get power. something stupid like a solenoid under the passenger side dash clicks when i actuallyget some power, but the car wont start.
I bought 2 new circuit breakers and pulled every fuse in the fuse box and nothing helps. The car just chooses when to die or start on its own. the cat got clogged around the same time this started happening. I got a whole new exhast pipe and cat, but this strange electrical problem is still here. I might replace my ECM but i dont want to if its not going to do any good. my car also backfired a few times when the problems started and it dieseled today but i think thats because all the fuses werent in. I read some posts and i saw that it could be fusible links, but why would it start sometimes and act like the battery is dead at other times..
Old Jun 22, 2003 | 06:38 PM
xChRiSx's Avatar
looks like nobody could help... but my uncles friend had seen the problem a few times before. all it was was the solenoid, car runs fine now =)
Old Jun 25, 2003 | 10:43 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
What happened - did the Positive wire come loose from the starter soleniod Or was the starter soleniod just a bad unit ??????
Old Jun 26, 2003 | 01:12 PM
xChRiSx's Avatar
how it was explained to me, since chevy puts the solenoid right by the exhaust pipe, the heat killed it and the whole thing was just going bad, i got a new on for $10 and it works perfect again
Lbibb
May 5, 2016 12:00 AM
Linson
Oct 1, 2015 09:50 PM
rusty vango
Sep 29, 2015 02:44 PM
RacerM
Sep 28, 2015 04:25 PM
manifoldsrme
Sep 17, 2015 11:40 PM
