dash lights....
Old Jun 19, 2003 | 11:07 PM
gameover9677's Avatar
Car: 1982 trans am
dash lights....
OK i have a 1982 trans am and my problem is when i turn the parking lights on everything works but when i turn the head lights on my dash Gauge lights go out i have looked at the fuse and the switch. i went out and got a new switch but it still does it
thanks
Old Jun 22, 2003 | 10:12 PM
T/A gets T&A's Avatar
Maybe a problem with the dimmer control?
Old Jun 23, 2003 | 12:47 AM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Check the potentiometer where the headlight switch is.. might be bad ?
Old Jun 23, 2003 | 02:16 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
look to the left side of the steering column as it starts to enter the dash, there is a metal reinforcement bar that runs under the dash, there will be two black wires bolted there, if there loose that will cause whats happening to your car, these are the dash harness ground wires
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
