How to wire up indicator lights for the fans?
Old Jun 21, 2003 | 05:00 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I want to know the easiest way to wire up some indicator lights so that I know which fan is running.
Could I run ignition positive to a light and then run a ground to the fan motor ground wire? Or are the fan motors always grounded?
I am looking for the safest way to wire up the indicator lights.
thanks
Old Jun 21, 2003 | 06:47 PM
scauffiel's Avatar
Hmmmm, I've often wondered about doing something like this myself. Though I've wanted to do it a bit differently - I wanted lights when my fan stopped working. Couldn't you just wire a light in series with your fan wiring? Just splice in a light? I mean, when there's juice going through the wire, meaning the fan is on, then there would be juice going through the light. No juice through the fan, no juice through the light; right?
Just my two cents Manny,
Steve
Old Jun 22, 2003 | 03:53 AM
Zepher's Avatar
That's one way to wire it up.
Old Jun 22, 2003 | 06:24 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Don't wire it in series, all that will happen is that the bulb will light but the fan won't turn. Tap into the blk/red wire of each fan relay with a 3M tap, put a little grease on to insulate it from water then run that wire to the center terminal of any 12 volt bulb and ground the other like any standard bulb wiring. Fan relay energizes and bulb lights. I would throw a small 1 amp fuse in each line as close to the relay as possible in the event of a short in the added wiring. I saw a tg locally where the guy used the "shift" lens in the light section of the dash. He used a green lens with silkscreened "fan on" letters. Really neat.
Old Jun 22, 2003 | 03:40 PM
Zepher's Avatar
I am thinking about putting 2 LEDs in the gauge cluster right above the temp gauge.
I am always checking my coolant temp and oil pressure, those are the 2 most important gauges to me.
Old Jun 23, 2003 | 05:49 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Very dooable! Cathode end of diode(led) goes to ground, anode goes to the relays like the bulb but use a 390 ohm 1/2 watt resistor in series. Different color for each fan, yeah I like it.
Old Jun 23, 2003 | 10:55 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
why not run a ignition feed to the lights, and then tap into the ground wire for the coolant temp sender
Old Jun 23, 2003 | 03:51 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
I think tapping to the fan wires at the relays is a better idea, that way if a relay fails you know the fan is not running when it's supposed to. And the 2 LEDs is the way to do it, they are not extremelly bright to become a nuisance.
Old Jun 24, 2003 | 10:42 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
That's what I did when I swapped an electric fan into the SC, except one fan=one LED. It lit up when the power was on, and faded out as the fan 'wound down' after power to the relay was cut. Also noticed at night, the LED would start to glow when driving about 50 mph....showing that the fan motor was turning fast enough to generate adequate current to light the LED.
Pete
Old Jun 25, 2003 | 08:36 PM
RPM WOT L 98's Avatar
Pete
I like that!
eightsixseven
Dec 16, 2024 01:50 PM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
