pushbutton ignition
Old Jun 21, 2003 | 09:53 PM
red305's Avatar
pushbutton ignition
I'm trying to wire this starter and getting extremely frustrated. chiltons isnt all too explanatory when it comes to the passkey system. anyone wire one before? 91 camaro rs
Old Jun 25, 2003 | 01:16 PM
JPrevost's Avatar
Car: 91 Red Sled
I've got a push botton ignition in place of my cig lighter. What do you want to know?
I wanted to be able to use it along with the key ignition. First thing I did was disable the VATS in the eprom, then I rewired the starter enable relay (behind drivers kick panel) to come on when the key is in the on position. From that I ran a positive red wire to the back of the fuse block where the large red wire comes in and then to the tan w/white wire. This way the push button starter is just an override and still requires the key to start the car, also having it go into the tan w/white wire makes certain you don't start the car when it is in gear (or clutch is out).
I was able to locate a harness plug that was left open and had both the tan w/white and purple (direct to starter) wires. If you can find that then just run a wire from the new pushbotton starter to that plug with a simple male blade terminal end. It's PLENTY tight in the harness that you won't have to worry about it coming out. Any other questions?
Old Jun 25, 2003 | 07:18 PM
red305's Avatar
I thought i did that, I tried both brown wire and the purple wire...but I didnt disable anything in eprom, hows that done.
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
94ElBanditoDeCa
Aftermarket Product Review
Sep 23, 2015 09:05 PM
RedLeader289
Sep 23, 2015 06:50 AM
