81 Z28 Cowl Induction Scoop Wiring
Old Jun 27, 2003 | 05:40 AM
spatter1's Avatar
Car: 89 RS
Engine: LO3
Transmission: TH700R4
I have a cowl induction scoop from an 81 Z28 that I installed on my 89 RS and I was wondering if anyone knows how to properly wire it up so that the flapper doors open at WOT.
I did not get a chance to see how the switch functioned on the car that it came off of. So I don't know how or where the switch was installed or if there was a relay in the system that triggered the flapper door motor.
There is a spot on my gas pedal bracket that I could mount a switch... but I am still unsure about the relay.
Or, if anyone has any experience in the wiring for the early third gen z28 ram air, that probably uses a similar mechinism.
Thanks for your help.
Old Jun 28, 2003 | 08:07 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
you could use a vacuum switch from a 84 trans am, all you do is run a vacuum line from the motor to it, then a ignition feed to the actuator motor and the switch grounds the actuator under full throttle conditions.
Old Jun 29, 2003 | 07:21 PM
spatter1's Avatar
Car: 89 RS
Engine: LO3
Thanks for the advice... now I just have to find one as well as the motor that actuates it (burned it out). Do you know if there is a relay in there anywhere?
Old Jun 30, 2003 | 01:09 AM
Jproz1167's Avatar
spatter email me might have what you need
Old Jul 2, 2003 | 07:19 PM
spatter1's Avatar
Car: 89 RS
Engine: LO3
Sent you an email, but I don't know if you received it or not. I am interested in the parts, let me know more.
Thanks.
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
eddie jr
Aug 25, 2015 06:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
