no negative and the gauge works!!!
Old Jul 8, 2003 | 10:43 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
okay i have an auto meter electric trans temp fluid gauge.The electric send is in a t fitting and then with rubber lines clamped to the metal cooler lines.So the sender has 1 wire to the gauge and then a postive wire to a power source.But it reads the temp with out having the ground hooked up but the wire is connected to the gauge but the wire isnt touching a ground.So was wondering if im getting the right readings.
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
