Ticking noise from headlights?
Old Jul 13, 2003 | 10:51 AM
1gta2c's Avatar
Once and a while I hear this ticking noise from my headlights. Is it the relay or is it the motor itself. I turn it off and on and it goes away. 91 gta.
Old Jul 18, 2003 | 09:48 PM
BlackBeast'88's Avatar
Car: '88 Formula
Engine: 355cid
I'll bet the lights aren't poping up properly are they? You need to replace the worn out bearings in the headlight motors. This will fix the problem before it gets worst.
Old Jul 18, 2003 | 09:58 PM
1gta2c's Avatar
The headlights work fine. When they go up there is no noise. But once in a while when they go all the way down they keep ticking untill I raise and lower a couple of times. Besides this they work great.
Old Jul 22, 2003 | 08:57 PM
1gta2c's Avatar
Could this be the headlight control modual? I let it turn off and it started clicking and then I un-hooked one of the motors and then pluged it in and the noise went away??? Any Ideas 91 gta.:lala:
Old Jul 23, 2003 | 10:03 PM
Car: '88 Formula
Engine: 355cid
You need to replace the gears in the motors. Each motor has 3 plastic ball bearings and over the years they have crumbled. It costs about $2.00 and takes about 1hr to do the job.
Old Jul 27, 2003 | 09:26 PM
MFaulkner's Avatar
Car: 90 Formula
Engine: 305 TBI
Mine click nine times. That's the sound of the clutch mechanism skipping, keeping your gears intact.
Old Aug 2, 2003 | 09:08 AM
1gta2c's Avatar
Well I replaced the plastic ***** in each motor and it is still doing it.I pulled out 6 perfect original plastic bearings and no wear on any of these parts. I have a new headlight controal modual and it does the same thing. Are thier any other adjustmebts to make???
Old Aug 3, 2003 | 10:05 PM
Car: '88 Formula
Engine: 355cid
What did you replace them with??
Old Aug 4, 2003 | 07:58 AM
1gta2c's Avatar
the rebild kit that you buy from tds.
Old Aug 4, 2003 | 10:13 AM
Car: '88 Formula
Engine: 355cid
Well if it wasn't the crumbled bearings in the motors I don't know what it is. But somehow I still suspect its the bearings in the motors...
Old Aug 4, 2003 | 10:57 AM
1gta2c's Avatar
Well I took out 6 perfect nylon bearings and replaced them with the 6 that came with the kit. I put the grease in as per inst.. and it still does the same thing once in a while. I could send you a pic of the origonal ones I pulled out, they are in perfect shape with no ware.
Old Aug 7, 2003 | 09:15 AM
Car: '88 Formula
Engine: 355cid
The original bearings you took out weren't crumbled?
Old Aug 7, 2003 | 07:12 PM
1gta2c's Avatar
No they are in perfect shape all 6 of them, a little yellow though.
Old Jan 23, 2012 | 10:55 PM
jarredsoon's Avatar
Re: Ticking noise from headlights?
Any solution to this problem??? My headlight tick tick tick when in the down position and I too have new bushings
sjorgens
Oct 1, 2015 07:54 PM
meeklay812
Oct 1, 2015 03:46 PM
