ignition noise
Old Jul 17, 2003 | 07:35 AM
novakm's Avatar
ignition noise
Ok, I did a search and tried the grounding stuff. Need help.
I just put TPI into my '71 chevelle. Now I get ignition noise through the radio. It sounds like I'm picking up every spark.
It does not get louder when I turn up the volume. At very low volume I get a pretty loud whine. I can turn up the volume and the music gets louder but the whine stays the same.
Some days it's worse than others.
notes on the install:
all grounding goes directly back to the battery. several wires from the engine, manifolds, and chassis.
Power for coil is fed through a relay direct from battery.
any ideas?
Old Jul 18, 2003 | 01:21 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
There isn't a good battery to chassis ground. There isn't a good chassis to body ground. You're not using spark plug wires that have good RFI/EMI suppression.
Old Jul 18, 2003 | 11:15 AM
91blackgta's Avatar
you can also get a RFI suppressor, that goes inline on the power wire to the radio. IT helped mine. I had the noise too, i had the correct spark plug wires and added an extra ground. But the supressor solved it for me. Go to a car audio store and pick up one. They don't cost much.
Old Jul 26, 2003 | 05:49 AM
novakm's Avatar
Thanks, Problem solved.
I used an RFI suppressor from Radio shack, noise gone. Seems it was not ingnition noise, but noise from the charging system.
You guessed it, two days later I only have 10v and car won't start! Either alternator or regulator was bad. Replaced it.
MIke
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
