headlight relay diagram
Old Jul 28, 2003 | 01:45 PM
dave89gta's Avatar
Anyone have a wiring diagram for an '89 GTA headlight relay?
I did a search and only found diagrams of earlier years. My lights wont go up or down, and I want to do some diagnostics.
--Dave
Old Jul 28, 2003 | 02:56 PM
dave89gta's Avatar
Ok, update; the relay does apparently work. I can hear and see it click when I switch the lights on. On the 4 pin side, all wires (2 green, 2 gray) are seeing 12 volts in both the off and on positions. 3 of the 5 wires on the other side of the relay are seeing 12 volts in the off position. Dont remember which, and dont know about the off position. The motors both work properly off the battery, although the driver's side continues to run after the light is up. The **** never tightens in either direction.
Old Jul 28, 2003 | 04:29 PM
dave89gta's Avatar
I put voltage/ground to both sets of gray/green wires at the relay, while the relay was disconnected. Then I plugged in the headlights again and they worked ok. This was the case for both sides. It just doesnt work if I connect the relay. All 4 wires, green and gray, have voltage in both on and off positions. WTF?
I am probably going to go get a new relay, and see if it fixes the problem.
Old Jul 28, 2003 | 10:39 PM
2vmodular's Avatar
follow the link in my signature to view a larger version of the above diagram.
InfernalVortex
Apr 20, 2021 11:31 AM
thunder57
Nov 7, 2015 02:28 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
