one strange azz question!!
Old Jul 28, 2003 | 08:14 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
alright guys i guess this is where id post this question...
anyway,this is a very strange question....whenever i start my car up,the left blinker light comes on & wont go off until i turn the blinker thingy either up for the right one or down for the left one,it all started today....whats up with that??? is it a short somewhere? anyone else ever had this trouble?
Old Jul 28, 2003 | 08:32 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
What ever side of the blinker is lit up, check the parking and brake lights, and make sure the blinkers work on that side of the car.
Old Jul 28, 2003 | 08:41 PM
Engine: 283
yes they are all on but now whenever i just started up the car of course as my luck would have it the blinker light inside the car is not on whats up with that??????
Old Jul 28, 2003 | 08:55 PM
Dirty Rob's Avatar
You dont happen to make a left turn into your driveway do you?
Old Jul 28, 2003 | 08:58 PM
Engine: 283
sure do.....why? thats bad isnt it???????
Old Jul 28, 2003 | 09:14 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Do you put your blinker on to turn into the driveway?
You might have better luck in the electronics board.
Old Jul 28, 2003 | 09:20 PM
Engine: 283
yes i always use my blinkers-lol.....
thanks! never thought about the electronics board can someone move this for me please?
Old Jul 28, 2003 | 09:23 PM
Dirty Rob's Avatar
Before you turn off the car, make sure that your blinkers are off. Then start the car again, and see if the blinker turns on when you start it. If this solves the problem, tell no one.
Old Jul 28, 2003 | 09:29 PM
Engine: 283
roflmao!!! im 100% sure that both the blinkers are off whenever i do turn the car off.....i havent been smokin or drinkin anything except tea-lol
Old Jul 28, 2003 | 09:32 PM
Dirty Rob's Avatar
Glad weve got that taken care of then. It might be a relay getting stuck or something. Im sure this can be worked out when it gets moved to the electronics board.
Old Jul 28, 2003 | 09:40 PM
Engine: 283
it must be that ghost again
i probably shouldve added that its not like the blinker is turned on,it is just that the light inside the car is on but aint blinking...i dont know i have one very haunted car-lmao
Old Jul 28, 2003 | 09:43 PM
Engine: 283
moderator...can you please move this thread to the electronics board? thanks!
Old Jul 29, 2003 | 02:48 AM
Morley's Avatar
Try a new flasher unit, probably stuck or flaking out on the inside.
Old Jul 29, 2003 | 04:41 PM
Engine: 283
how do i go about checking out the flasher unit to see if yes it does need replaced or no its that ghost??? any way to tell for sure??? also lets say the unit would fail,that wouldnt mess with the brake lights would it? i know the lights on moms jeep went nuts whenever she had a blinker light out...you pushed it up for the right one & the left one would blink & vice versa
Old Jul 30, 2003 | 01:43 AM
Morley's Avatar
It is a small round "can" up under the dash, driver side towards the middle. There's no telling what it might do if it goes bad, they only cost a couple of dollars, just replace it to eliminate it as the problem.
Old Jul 30, 2003 | 05:04 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
thats what i would do (above) if all you lights work, check all your outside bulbs first (turn blinker on, get out, look ect...) if one is burned out thats your prblem, btw, my old jeep went ape **** when it had a bulb out. most cars do.
Cornholio7979
Sep 20, 2018 02:31 AM
someone972
Aug 30, 2015 12:52 AM
red90IROCls1
Aug 25, 2015 06:56 AM
overdriv
Aug 20, 2015 03:52 PM
redmaroz
Aug 16, 2015 11:40 PM
