removed A/C, can I still use 2nd fan?
Old Aug 2, 2003 | 01:36 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
I removed the A/C, with a dual fan set-up. Does this mean the second fan will not work anymore? From what I understand, the second fan will turn on when A/C is being used. Any help with this?
Old Aug 3, 2003 | 05:06 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
The aux fan should still function when the engine coolant temp goes above 243 degrees. Aux fan was controlled by A/C pressure switch, but also by the fan switch in the block on the pass side. As long as that is intact you should have no problems whatsoever.
Old Aug 17, 2003 | 06:11 AM
Ground Rat 69's Avatar
If for any reason the second fan does not turn on you can always run the wires to that fan to a switch mounted wherever you want it. That way, if you feel that you need more cooling you can control it. I know someone who did this while stationed in North Texas. He had a Ford van with a 460, but the principle is the same.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
NiG
Oct 11, 2015 08:42 PM
3rdgenparts
Aug 8, 2015 07:09 PM
