Headlight problem? Help!
Old Aug 5, 2003 | 03:08 PM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
Ok I noticed that on low-beam, my driver's side headlight is out. So I'm like "Crap! Gotta replace it!", then I put on my high-beams, and all four are lit up. Now I'm like "CRAP! I've got an electrical problem!" Can you guys help? I don't know how to trace this stuff down, but if you tell me to test something with a multimeter or something, I can do that lol - I just dont know where to start for s weird problem like this. Thanks.
Old Aug 6, 2003 | 11:30 AM
badjuju342's Avatar
Car: '89 rs convertible
Engine: ls1
Axle/Gears: 3.73 posi
if you look on the back of the low beam you'll notice,that there is three prongs unlike 2 found on high beam,try this;swap suspect low beam with good low beam and see if this correct problem.low beam have 2 elements instead of one like on the high beams.this test is easy ,and best of all,IT'S FREE
Old Aug 6, 2003 | 01:11 PM
jamesbob02's Avatar
Car: 92 Z28
like the low-beams have two different lights in them, so a different light comes on inside the low-beam when high-beams are put on? Ok, I'll see what I can figure out.
Old Aug 6, 2003 | 01:24 PM
badjuju342's Avatar
Engine: ls1
yup, that is it perzactly.i'm sure this will solve your problem
Old Aug 6, 2003 | 05:30 PM
jamesbob02's Avatar
Car: 92 Z28
K thanks. Knowing this, I bet you're absolutely right.
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
