no dome light, no stereo power!!
Old Aug 8, 2003 | 02:35 PM
Cyrozis's Avatar
Car: 83 Z28
Engine: rebuilt 78 350
Transmission: not sure
I am replacing my headliner so when i took the dome light bulb out the stereo would not even power on any more. the car runs and other lights work but the dome light does'nt and neither does my stereo. Whats going on please lend some advice.
Also when i was changing my back right speaker the speaker just stopped working. No speaker will work on the back right but it was working fine seconds before. what is wrong with that?! just one of those moring so it seems.
Old Aug 8, 2003 | 09:05 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
i bet your cigarette lighter doenst work either, check the fuse, the fuse panel is right above where your left leg is when your sitting in it
Old Aug 9, 2003 | 01:12 AM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
If it is the fuse, it should be the one labeled ctsy. It's a 20 amp i believe. It's yellow. Hope this helps.
Old Aug 9, 2003 | 01:29 AM
Cyrozis's Avatar
Car: 83 Z28
you guys are geniuses !!! my horn wasn't working either....thank *** for fuses....i was new to the fuses and exactly which things connected to eachother...thanks for the help
as for the speaker...could it just be bad speaker wire that just gave out or is there a fuse for that as well???
Old Aug 9, 2003 | 05:14 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
yeah, idk how many times i've blown that fuse... my friend put in a new overhead console and everytime he opened his door (i.e. dome light come on) the fuse would blow power wire was shorting to the body ground... lmfao
justin57
Aug 20, 2015 07:05 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
