no start
Old Aug 8, 2003 | 02:53 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
no start
just finished swapping a carbed V8 for the meek V6............
i have power to all my fuses, but my fuel pump does not turn on
and the car will not crank
i am running the stock electric fuel pump to a 3 port regulator
any help is appreciated
VATS possibly?
thanx
Old Aug 8, 2003 | 03:55 PM
ok, i just bypassed the starter enable relay, but it still wont crank
i am leaving the ECM/ harness in, btw, in case i ever want to switch to EFI
Old Aug 8, 2003 | 06:39 PM
Tyler-88's Avatar
even power to the fuel pump fuse when you turn on the key? and hows everything look at your fuel pump relay. i had a wire pop out of my relay harness plug once.
Old Aug 8, 2003 | 08:08 PM
tyler-
the ecm wire off the battery, where does that connect to?
i think that maybe the problem
(for the fuel pump atleast)
Old Aug 10, 2003 | 03:30 AM
Tyler-88's Avatar
jesus, i do not know. my setup is all different after relocated both batteries to the hatch. iam not sure if you need the ecm to run the fuel pump or not. id find the power wires for the fuel pump relay and check to see if you have 12+ when you turn on your ign (for 2secs when you turn the key on). im probably not the best guy to ask for help on this. i would also just trace all the wires from the bat to where ever they go just to make sure there is a solid connection. maybe search for a diagram of the fuel system. its late and iam unable to think of how the fuel pump gets its power. sorry
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
