Headlight Dimmer Switch
Old Aug 14, 2003 | 09:18 PM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
When I move the dial up or down, nothing happens at all except it turns the dome light on when Im inside the car, but it dont dim the interior lights under the gauge cluster. Whats wrong? How do I go about fixing this problem? Thanks, any suggestions would help. I have the 86 T/A with the mechanical gauges if that helps.
Old Sep 3, 2003 | 03:58 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Exact same problem im having, hope someone knows...
Old Sep 3, 2003 | 04:34 AM
allboutspeed's Avatar
Car: '87 IROC Z-28
Engine: Horse **** 305 for now
Axle/Gears: 3.73 posi
Had the same problem. Found severe oxidation on the reostat part of the switch. Caused constant voltage to the lights. Try a new switch they're cheap.
Old Sep 3, 2003 | 10:48 AM
ramrod85's Avatar
Car: 85 Z28
Engine: 350/ 290hp EZ-EFI
Axle/Gears: 3.08 posi
It's a little tricky to change. You can pick one up from autozone for less than $20. A manual that shows how to remove the old switch will help.
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
Randomtask2
Sep 10, 2015 08:37 AM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
