Interior DashBoard Lights
Old Aug 16, 2003 | 11:19 PM
jdrafke's Avatar
WEll i cant figure out y my darn interior dash lights dont work. Im refering to the lights that light up around the guages and the shifter. The outside lights work when i pull out the *** but the interiordash and shifter dont work. Hoever, when the *** is pulled out and the headlights are on if i tunr the *** all the way to the right nad barely push it in the lights coem on! But as soon as i let go they go off. What is losse and causing this, How can i fix it! Please help
Old Aug 17, 2003 | 12:09 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
sounds like it might be your hd light switch?
Old Aug 17, 2003 | 10:17 AM
jdrafke's Avatar
Yes when i pull it out and push it in just a bit the lights will come on until i let go and then they go off. Is there a fix to this
Old Aug 17, 2003 | 10:18 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
replace the switch about $10 at autozone.
Old Aug 17, 2003 | 03:01 PM
TJQIROC's Avatar
Car: '16 Camaro SS, '88 IROC
Engine: 6.2 Gen V
Transmission: 6 spd TR6060
Had the same trouble only mine would work if I worked the **** a little. Just changed the switch today. I was sort of a pain. The instrument panel has to come out which is not that hard except for the speedometer cable.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Omega
Aug 10, 2015 12:46 PM
