:lala: My headlights, power locks, power hatch, and interior lights arent working !! I need help! PLEASE! lol...... umm, I'm trying to find the fusible links for the headlights right now, im thinking that might be the problem, but im not sure. Any help would be really appriciated.....big time........Im lost when it comes to the electronics........
please help
:lala:
Me if i get help -------> :lala:
please help
:lala: Me if i get help -------> :lala:
Petes 84Z28
close
There's two, sometimes three of them on the large terminal of your starter.
Pete
Pete
do you think thats the problem though? cause soooo many things are out right now...... and what does a fusible link look like? lol
this guy is awsome ----->:lala:
well,that large red going into headlight switch is constant power feed,does it show 12v? links on large terminal of starter just like last reply stated
You seem to have multiple problems bro. Your problematic items all run off separate power sources. Your interior lights run off the CTSY 20amp fuse in the fuse box under the dash, and your power locks rub off the same fuse plus a 35amp POWER ACC fuse. The trunk pull down on the other hand I could not find either so, you will have to trace the power wire back until you loose power. Good luck.
