Code 54
Old Aug 27, 2003 | 03:48 AM
Tuppidsay's Avatar
Car: 88 Camaro IROC
Engine: 5.0 TPI
Code 54
My 88 Iroc 305 TPI has problems starting. It cranks for a while then starts. Sometimes shorter, sometimes longer. Can't find any common ground with the occurances. So I took it to shop for a fuel pressure check. They said when you first start cranking you get around 10 PSI and then when the car starts you have 40 PSI. Then he said i wasn't getting enough voltage to the pump and that there was a code 54. The car always starts just it takes a little while. So i figured, what's 15 bucks and bought a new fuel pump relay. Didn't fix the problem. The pump sometimes stays on for a long time after the car is off. Sometimes hours after. havn't checked for this since the new relay. My dad thinks it may be a faulty ecm. I hope not. Anyone had this problem? Any ideas on how the diagnose it?
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
