fan switch keeps melting! help!
Old Aug 27, 2003 | 05:09 PM
deadonion's Avatar
HI
I have an 89 firebird, and a couple years ago I dropped in a 350, and took off all the fuel injection and put on a carb.
I ran the radiator fan through a toggle switch.
this lasted about 30,000 miles.
the other day the switch burned out
I replaced the switch with a 25amp unit and 10gauge wiring, the switch lasted about 2 days and it burned out again.
I now am running a 30amp switch, but after 1minute of bieng on the switch and wire connectors get so hot I cant touch them.
when i turn on the fan, the voltage drops down to about 9volts, and the rpm drops, almost as if the AC compressor is turning on(it is not turning on) it also makes a very loud noise almost like a turbine spinning up.
the fan will rotate freely when spun by hand.
please help, im sick of driving around with the heater blasting!
thanks in advance
JL
Old Aug 27, 2003 | 06:06 PM
armac's Avatar
Car: 83 ta
check the ohms of the wiring and the fan motor. something is causing it to pull way to many amps. If this is all the sudden suspect the fan motor.
Old Aug 28, 2003 | 02:35 PM
allboutspeed's Avatar
Car: '87 IROC Z-28
Engine: Horse **** 305 for now
Transmission: 700-R4
Axle/Gears: 3.73 posi
Totally agree, prime suspect is the fan motor itself. If it is shorting out it will still spin freely. You might also want to run through a relay vice straight wiring it to the switch (safety)
Old Aug 28, 2003 | 05:04 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
You definitely need to run a relay...the stock fan will draw over 25 amps during startup.
Pete
Old Aug 28, 2003 | 06:32 PM
deadonion's Avatar
thanks for the help, fortunatley its a pretty cheap repair
JL
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
