blinker problems...
Old Sep 2, 2003 | 10:40 PM
KL89's Avatar
blinker problems...
ok, this is my first post here. I have been looking through this website for about a year or so and just got me an account... so anyways, this is my problem: my left blinker lights all work, my right blinker front lights work but don't blink, the back blinker light doesn't even work, the fuses look fine, the bulb is fine. The bulb isn't getting any power.. I'm not too sure what it could be. maybe the flasher? maybe i'll have to rewire the taillights which won't be too bad. anyone know what could be the problem?? maybe a loose connection somewhere? Thanks, i know this might be somewhat of a stupid question but oh well. I'm new so`BE NICE.
Old Sep 3, 2003 | 07:15 AM
1986redbird's Avatar
recheck the bulbs in the back of the car, if even one bulb is out the rest of the blinkers on that side won't work, they will just be steady on. since your front bulb lights I doubt it's the flasher unit.
I'd be willing to bet it's your rear turn bulb is bad, they're only about a $1.00 so it wouldn't hurt to replace it anyway, sometimes they go bad in places you can't see.
Old Sep 3, 2003 | 12:05 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
If one side works fine, then the flasher is good.
As mentioned above, double-check the rear bulb. If you have, or can borrow, a voltmeter check at the bulb socket to see if power is getting to it, and if the ground is good. If it isn't getting power, it's likely a broken wire somewhere.
Pete
Old Sep 3, 2003 | 02:13 PM
KL89's Avatar
I did get a voltmeter and check the bulb socket, and it's not getting any power to it. There must be a broken wire somewhere, thanks for the help.
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Jk_Under
Sep 2, 2015 10:59 PM
loc0bob
Jun 3, 2001 12:27 AM
super83Z
Jun 2, 2001 10:44 AM
Jimmy91RS
Sep 28, 2000 02:16 PM
