Headlight problem
Old Sep 3, 2003 | 09:24 PM
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
Headlight problem
I was on my home from work, and after a hard day at work, i wanted to put my leg out so i could relax, i put it past the clutch to about where the foot rest thing in autos is, and my headlights cut out! I moved my foot, they came on, i moved it back, it went off..... Any ideas how to fix it? thanks!
Old Sep 4, 2003 | 09:14 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
You have a bad connection. The only way to fix it is find the wire or wires that are bad by wiggeling them to see which one has the bad connection, or short.
Old Sep 5, 2003 | 05:49 AM
allboutspeed's Avatar
Car: '87 IROC Z-28
Engine: Horse **** 305 for now
Transmission: 700-R4
Axle/Gears: 3.73 posi
That is where the wires go through the fire wall. Pull the carpet back and fix your eroneous wires.
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
