i need a chip burned for a 92 to remove the vats
Old Sep 6, 2003 | 02:00 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
i need to have sombody burn my chip to remove the vats so that i can finish my engine swap. any suggestions or if you can burn one let me know a price.
thanks
Old Sep 6, 2003 | 06:33 PM
onebinky's Avatar
if you want a really cheap way to bypass vats, just cut the 2 wires going up the column (I think its white and purple) and splice in a resistor the same value as the key. To read the key resistance, just put one lead from a multimeter on each side of the little pod on your key.
Let me know if you have any questions on how to do it
Matt
Old Sep 6, 2003 | 06:53 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
i would but i swapped the motor into an s-10 and its all diferent.the only thing i think i can do is to find somone who can burn it i guess????
Old Sep 7, 2003 | 07:49 AM
idrag2's Avatar
What year of s-10? I don't think it will matter what you put it in, your s-10 should still have the resistor in the key, therefor you can cut the wires coming off of the lock and tumbler and splice in a resistor.
Old Sep 7, 2003 | 02:28 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
nope its a old one... a 83 that is in good shape so we are gonna do a fuel injected v6 swap. so pretty much my only option is to have it burned.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
NBrehm
Aug 25, 2015 11:49 PM
stalkier
Aug 13, 2015 12:59 PM
Exxon Limited
Aug 9, 2015 08:13 PM
3rdgenparts
Aug 8, 2015 07:09 PM
