"acc" fuse keeps blowing out! help me
Old Sep 11, 2003 | 09:05 PM
primerinstinto's Avatar
i have a 92 firebird 350. and the "acc" fuse keeps blowing up, it's a 20 amp fuse, it controls the rear hatch, and the power mirrors i believe, i dont know what the problem is, can some body please help me? pleeeaase! thanks -----jorge
Old Sep 11, 2003 | 10:32 PM
BIGJsTA's Avatar
That fuse actually runs to several things, courtesy light, cigarette lighter, radio ect....The power ACC fuse runs to power windows, door locks, mirrors, ect. The wire is probably shorted, best advice i can offer is trace the wire from the fuse (prolly an orange one) as far as you can, look for the insulation stripping away in parts or anything that might cause it to short. Is the fuse blowing RIGHT AWAY when you stick a new one in?? Or only when you turn certain things on?
Old Sep 12, 2003 | 08:23 PM
RySeyes's Avatar
I have the exact same problem. That fuse takes a 20 A fuse, so I tried putting in a 25. Lasted a lot longer, but it finally blew out yesterday after about two weeks. It's annoying...I lose my horn, dome light, cig. lighter, and if I had a working stereo that'd be wacked too.
I wish I could follow the wire, like you said.
Old Sep 12, 2003 | 10:03 PM
BIGJsTA's Avatar
If the fuse lasts for days or weeks or months but allways blows, my money says your power wires had the insulation stripped away somewhere. Especially if the fuse blows when your not using anything, just the vibrations from driving will shake the wires, and it's probably rubbing against a ground connection and shorting out. A larger fuse might mean you need a more solid 'rub' to short, but i wouldnt recomend going any bigger, the fuses arent the problem they're just protecting you from some far worse symptoms. I would check your cig. lighter, your dome/courtesty lights, and your radio. None of those run in the wiring harness they're all just kinda loose...Not too hard to remove and check either. Most likely it's one of those that is shorting you. Especially with radio's installed by previous owners, you never know what the hell they were thinking.
Old Sep 13, 2003 | 09:36 PM
Tonyrodz's Avatar
Transmission: auto
check your loose radio wires. I had the same thing happen to my 85 Z--took the radio out but forgot to tape up the wires so every time the pwr wire hit the metal bracket I'd blow the fuse--along w/everything else on the acc fuse.
Old Sep 13, 2003 | 10:11 PM
1986redbird's Avatar
don't forget to check for the dreaded "coin in the cig. lighter" problem, camaros didn't have this problem but firebirds have almost all had this at one time or another.
Old Sep 13, 2003 | 11:05 PM
CamaroFreak87's Avatar
Car: 1987 Camaro IROC Z-28
I had same problem, my dome light/power windows/power locks would all of a sudden go out. would have a blown fuse. would replace the fuse and it would blow about a month later. Solution: take the cigarette lighter out of the car. The cig lighter was some how shorting, not sure where, but the fuse hasn't blown in over a year since then. Might have just been my car, might not be. worth a try.
Old Sep 15, 2003 | 03:31 AM
fuse
i found out what it was!!, it was a couple of coins that where stuck in there, it's amazing what a penny will do to your car! well, now i know how sensetive these electrical systems are on these cars, somebody emailed me and told me to check for change, and bingo, it worked---good luck guys--jorge
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
90formulaVortec
Sep 3, 2015 09:26 AM
